As stated above, I recently upgraded my flux 2 injectors to custom 3. 5 and also had my stg 1 cp3 upgraded to a stage 3. I love the way my truck drives when I 'm only running my injectors and ez, but as soon as I throw my smarty (above 3) or my tst (above 3x3) my truck fuels way to much and I get that throttle hangup where there is so much fuel being dumped, after I let off the throttle my truck continues to keep plowing forward. The only way I can fix that is to put the truck into neutral for a few seconds then put it back into drive and all is fine, until the next time.
I never had this problem before I changed these two things. Now my goal was to eventually turn this truck into my drag truck only, which is why I did these upgrades. Now I'm not sure I made the right decision. Can't afford another truck right now, so I still have to use this truck as my daily driver and work truck. Has anyone else experienced these hangups, or would this problem I'm having be solved with a set of twin turbos? Just looking to see if anyone else has ran into the same problem I'm having, or get some suggestions. I love my truck, just isn't as fun to drive now.
Chris
Chris
