Its all coming together update 12/13
transmission came in Wednesday. Everything else from Dodge was here Thursday. Still waiting for adapter kit form Blumenthal Heavy Duty. UPS hasn't delivered today yet so hopefully it will be here today. Also ordered a manual transmission filter kit from Geno's. The part number for the rubber rear transmission mount used in the 98 and later Rams is indeed 52058219 which changes to 52020251AA in the Dodge parts system. It is not listed in the 98,99,00,02 parts book. There are various things listed as insulator, engine mount, that the picture shows the rubber part I wanted but none of the part numbers that go with the pictures are the correct part number. The 01 BE parts book lists the part number but indicates that this part only fits gas engines. Most years they just list the front engine mounts here again for the diesel application. It is not properly listed anywhere that we could find. We were tipped off to the problem in the STARR computer when we looked there. The diesel application only has 2 attachments to the frame on the truck! IE there is no rear mount for a diesel according to the STARR or parts computer!
Another problem; there is a piece of 1/2" rod that is attached to the front exhaust pipe that is inserted through a rubber grommet that is attached to the rubber transmission mount. If you move the transmission mount 6 inches aft the front exhaust pipe mount is no longer going to hold the front pipe. This requires a different Dodge bracket that is now ordered. This bracket appears to use two bolts on the front of the transmission for attachment.
UPS is here! Blumenthal's adapter kit has arrived. It includes a modified (longer) Dodge transfer case shift linkage rod, Dodge NV 5600 transmission shift lever (52107612) , Dodge shift lever handle (52104174) and 6 speed insert (52108192), a 6 speed adapter plate that is not an OEM part (piece of 1/4" steel plate with 6 holes)(OEM part 52019603AB), a 3/16" steel plate adapter bracket to mount the transfer case shift lever on for the 94-97 transfer case shift levers that mount to the NV 4500, (pretty simple to make, I could have made it) and a backup light switch wire extension.
The transfer case shift lever bracket requires that one of the bosses (visible in the Blumenthals add on page 72 of issue 38 but on the opposite side of the transmission than that shown) be drilled and tapped. I haven't figured out what the OEM bolt size is yet but I will let you know.
One more thing I found interesting, the NV 5600 has a fill plug with a female 17mm hex. Now how many of us have that large a allen wrench in our tool boxes?
They did include the $56 backup light switch in my new transmission though. Wasn't that nice of them!
I'll keep you updated but it looks like this will be a piece of cake now that I got it all figured out! I think!!Ken Irwin
