Nothing earthshaking - just a pictorial showing one half a NV-5600 with a Fast Cooler, and the other half with a filter installed. The Fast Coolers and transmission lube filters are available thru Genos thru this board.
The purpose of the coolers are to both provide added transmission lube cooling and also add lube capacity for better overall transmission operation and lifespan - looks like this installed:
The added PC-type heatsink was done as an experiment to see if it added any significant cooling effect to what the Fast Cooler already is supposed to provide - I have NO illusions as to any vast benefit, just figured it was worth a try. As can be seen, I also have mounted a heat sensor to monitor the case temps in down-the-road situations - perhaps not the same as an actual temp sensor bathed my the lube, but all I have at the moment. The addition of these 2 items, plus a little overfilling allowed 6 quarts in the transmission.
The other side - the filter side also has an added heatsink - and the filter obviously deflects a percentage of operational lube flow into a cavity, then thru a small filter, then back out to the main transmission case.
Reports from users indicate the filters really catch lots of crud, and I also added a powerful magnet inside the filter cavity of mine for some added benefit in attracting and retaining damaging ferrous materials. At 50K miles, and several lube changes, this was the first time I'd had the side covers off and attempted to clean out the transmission sump and magnet - both were very filthy, and certainly needed cleaning!
A couple of 50 mile runs over a pair of local 5000 foot mountain passes while towing my 12 foot fishing boat and gear delivered a nominal 50 degree temp rise - ambient outside temps were 75 degrees, the transmission monitor registered +- 50 degrees higher - I'm very curious what other users with a setup like mine - or just the coolers alone, typically see in terms of temperature rise in varying situations?
My digital temp monitor tops out at 156 degrees, so I'm pretty certain a hot summer day towing our 5th wheel will put it well off scale - but I also have an infra-red handheld temp monitor to use at higher temperatures...
Any comments?
