As I remember, per Dave Fritz's website; the NV241 is rated at 1,028 lb. ft. of input torque whereas the NV241HD is rated at 1,400 lb. ft. In addition, the HD has a heavier duty chain that is also one row wider. As I've said before, best "$100. " I've ever spent!
The funny part about it is prior to ordering my Ram several dealers told me the ONLY difference between the two was PTO capability for the NV241HD.
I went ahead and ordered the HD and then stumbled across the info on Dave's website. I sure would have been pi$$ed if I'd taken the word of several salesman and ordered the non HD. BTW, one of the salesman worked for the largest Dodge truck dealer in the USA.
John Treibel
'98. 5 2500 QC 4x4 Sport, Glasstite Vision II, 285 BFG A/Ts on M/T Challengers, Warn 4X Boards, Mopar fender flares & tow hooks, NW Custom s/s-rubber mud flaps and accs. , Mag-Hytec diff. cover & trans. pan, Edelbrock IAS shocks, Reese Titan V hitch, SPA gauges (3), Dynamat, '00 Sport grille and headlights/PIAA Super White bulbs, PIAA Dual Sport 900 aux. lights, BD exh. brake, Amsoil Dual Remote Bypass, Optima Yellow Tops, DD3s and DD TTPM, Aeroquip AQP braided s/s fuel hoses, Banks High-Ram intake manifold and 14 cm2 turbine housing w/Big Head wastegate actuator, ATS 3-piece exh. man. , Banks 4" dia. s/s exh. sys. , DTT 93% TC, DTT custom tuned VB, BD modified trans. front pump (enhanced by DTT), Air Bulldog induction hood (with NACA ducts), plus MANY other trick modifications
NRA Life (Patron) member
