NV271 Transfer case leak
  • Thread starter Thread starter Deleted member 995608
  • Start Date Start Date
CI or CJ oil change?
Any problems cranking engine a bit without starting it?
D
Guest
I've got a leak between the T/C and my NV5600 transmission where they bolt up.
Is there a replaceable seal on the T/C? Or is it a seal on the output side of the transmission? Part #'s??
Thanks Bob. Any special pullers or seal drivers needed?
Seal drivers are always going to make it easier but not 100% neccessary
I have a good set of seal driver so that's good.
I may end up letting my local diesel mechanic do the clutch job. I found the receipt for the last time he did it and it was only a few dollars for labor and the rest was parts from the ******* that I bought myself.
I haven't been able to find a transmission jack to borrow or rent locally so I'll have to factor in that cost. That's why I may be better off letting the guy who has a lift, transmission jack etc to do it.
As much as I hate paying for work I can do, I might be money ahead.
