Had a wierd thing happen today while driving empty. Only happened for a few minutes... . The clutch would not disengage at a stop. Could not get into any gear whatsoever, When I tried to put in gear when engine off and restart, with clutch on the floor, the truck creeped forward... .
Have a SBC CON-OFE with not much miles on it an not many miles towing so I highly doubt anything is wrong with the clutch itself... has plenty of hold and I can shift ok RPM shifting... Have Redline MTL fluid in the transmission and maybe like 20,000 or so on the fluid... have to check the book... .
So at a light, tried to go into 2nd for a normal take off (empty) and could not go in, did the engine off and crank-start... for 3 lights and lucky on a few greens timing them, then, Miraculously, the clutch worked again, engaging like half-way up like normal and worked ok all the way home... ...
Was this a fluke or is it a sign of things to come... . Have read alot of threads about replacing the slave and some have had leaks and some the level was low... .
Mine seems perfect,
No leaks
Fluid full
Fluid clean
Slave tight to the transmission... no gaps... .
On the guys that replaced the slave they mention bleeding by taking off the slave and working the pushrod several times to purge any air that might be in the system... Do you think this would help on my truck with seemingly good fluid and level?
I need imediate advice as I am going to may Madness in Vegas towing my trailer so any help is apreciated.
Eric
Mine seems perfect,
No leaks
Fluid full
Fluid clean
Eric
