Engine/Transmission (1998.5 - 2002) NV5600 fliud change.
Engine/Transmission (1998.5 - 2002) Engine running rough
I only changed this one time a few years backso I need a refresher.
Loosefill plug slightly. Plate on side of transmission get unbolted. Drain fluid. Clean magnet. Bolt plate back on. Fill.
jeepit, are going to overfill the transmission, as been suggested on a thread a month or two ago? How many quarts will you use and which brand of fluid will you use?
george
I don't know if I will overfill or not. I have read a seal may leak?
Last change I used Amsoil MTL and i will probably use it again. Not sure about using any FM. I am on the fence with FM. If I would use it I would get it from Amsoil.
