My truck still shifts great. As the weather gets warmer it seems to help even more...
Hohn said:Y
I'm satisfied that the only contributing factor to shifting difficulties is lube-related in my case...
Heck, the stiff shifting started on the way down th FL from WY, when I had some high-mileage MTL in there. Thus the change to the Synchromax, which caused a huge improvement that soon disappeared only to go back to acting the same as the previous high-mileage MTL.
Confused yet?
Hohn said:Well, YMMV, but my experience with the RP was disappointing.
Lots of guys on TDR love the stuff
Maybe you should try it yourself and see if you like it.....
jh
nps said:8 months and 10,000 miles later the Redline MTL and Lube Gard are still holding up in my transmission. But it's never been in temps below freezing either. Wonder if that may make a difference in the stability - the heat cycle range the lube is subjected to?
One 9oz bottle of Lube Gard Gear Fluid Supplement-NAPA carries it. Read about it here. Hohn initially tried it but said it didn't last. As I said, so far so good.steved said:What Lube Guard did you use??
steved
steved said:I believe Pennzoil Synchromesh is the factory fill IIRC. I agree, I changed mine at 50k and it only made a slight improvement for a short time... I used PZ synchromesh.
I got a case of Royal Purple Symchromax sitting waiting for me to get off my butt to change... anyone else running RP??
steved
nps said:One 9oz bottle of Lube Gard Gear Fluid Supplement-NAPA carries it. Read about it here. Hohn initially tried it but said it didn't last. As I said, so far so good.
Hohn said:Yes-- as I stated-- this shifting was the same before and after the clutch install.
When the clutch went in, I had a new Super HD pilot bearing from www.quad4x4.com put it (the TK75).
Slave cylinder holds pressure just fine-- no leaks internal or external.
Confused yet?
rivercat said:How do you like your FE hohn? Mine is still grabby I think I got the pressure plate bolts to like 50lbs instead of the 29#s(i think) they recomend. I have slipped it a coulple of times too, prolly need to go pull a sled to fully break it in right.
Hummm - 2 of your 3 poor shifts are usually executed from a stop thus don't even exercise your synchros. The other (4-5) is going into direct drive. Wonder if your mainshaft is hanging up somehow. When you go from N-1 or N-R do you spin the input with the clutch, or have you been holding the clutch disengaged at a light?Hohn said:It seems that the toughest shifts on my 5600 are always Neutral to First, Neutral to Reverse, and Fourth to Fifth. If THESE shifts improve (which they are) then all the rest of the trans fall right in line.
jh
nps said:I'm thinking that there's something in your transmission/clutch setup causing the poor shifting that still hasn't been changed yet, even though you've already changed everything on the clutch side of the equation.
