I am planning a trip to FL from Upstate NY next month. I will be towing an enclosed utility trailer for a friend of mine who moved to FL last fall. My guess is that the trailer will weigh 2500-3000 pounds loaded (restored Model T stake truck and a few other things that didn't fit when he moved).
I'll be swapping my Reese WD/Dual Cam-Anitsway hitch from my TT to this trailer to ease the over-the-road feel.
I've done a bunch of PM work on my truck to get it ready but I wanted to check with you all to see if I missed anything or have any suggestions. I'll be rolling over the 100k mark on my odometer on the way home.
PM alread performed:
transmission/Transfer fluid change 22,000 miles ago (used OEM oil)
Diff. fluids changed 7000 mile ago (Amsoil 75w90)
Radiator Fluid and T-stat change last week (Fleetguard Compleat ES)
Brakes/brake fluid changed 11,000 mile ago
Still to do:
Replace original fan belt
Oil/Oil Filer/Air FIlter/Fuel FIlter change (I use Valv PB Extreme 5w40 with Fleetguard Filters)
Re-route the blow-by tube
Clean oil off radiator/engine from blow-by.
Calibrate elect FP guage with a manual guage to assure the my 12psi WOT reading is accurate.
Is there anything else?
I
Still to do:
I
