My CEL came on, with the TPS fault light as well. I believe the clutch/ignition safety switch caused the codes. I had the clutch pedal engaged at the exact position where it proves the clutch, and when I turned over the starter, it stumbled for a split second. The light cleared itself and the CEL just cleared itself. So I started researching for a good OBDII reader, but didn't want to spend lots of dollars. What I decided on I think is a very good choice as well as affordable, and I can even add devices like an EGT gauge, and up to 16 modules. And what is cool about it is that I use my iPhone for the display. My initial cost is only $200. 00 to start using it, that will allow the standard OBDII parameters, read and clear CEL's as well as many other features. I plan to add a trany temp module, rear end temp module, EGT module and boost pressure module if the reader can not see that. I'm hoping that it will tell me when its in regen as well. Here is the link www.plxdevices.com then you load an app that suites your fancy. I'll load the Dashcommand app when I get it. Click on the "OBDII to smartphone" link in the lower left of the page and then explore all of the modules.
All opinions welcomed!
