Obsolete Parts
I'm searching for rear window switch bezels for a 08 Ram 3500. The part is 5KC43ZJ8AA which is obsolete and I haven't been able to find any aftermarket suppliers for rear bezels. The front bezels can be found by a many Chinese replicas. the rear clips have broken and no longer stay in the secure in the door. Any ideas for fixes of retrofits would help.
I would think about using silicone caulk along the inside underneath edge of the bezel to hold it in place.
If you ever need to remove it again, the silicone will peel up relatively easily.
You might need to use some painters tape or a weight to hold the bezel in place while the caulk dries.
That is definitely a quick fix that would work. I wasn't thinking that simple. My head was going to plastic welding or fabricating some sort of metal clip on it. Silicone is a much simpler solution. Thanks
