hi there,
quick question, haven't been able to find anything in the forums about this...
Basically, is it bad practice to use an oil coated air filter in our engines? I'm running an aFe in the stock box and it is an oil coated filter.
I was told that such an engine will suck th oil off the filter and no longer really be filtering which will inevitably cause low compression and general engine failure.
Is this true? I've been running this setup for about 6 months. Should I change? What would you do? (I'm planning on getting a different air filter, a big one, but can't for a few months... no $$... ) Also, i'm about to clean the element, so if i'm going to change it out, i guess it would be now instead of cleaning... Should I really be worried that my engine could be dusted?
thanks. .
thanks. .
