Good discussion! First let me introduce myself, I am the owner of AdvancedLubeTech and I run the banner ad on this site for Amsoil products. I like that up front so no one thinks I am trying to keep that a secret.
The use of ail analysis is an excellent way to monitor the engine for wear, predict failure and check the condition of the oil. Your sample should have given you several indicators of the condition of the oil. These include the viscosity, TBN, fuel dilution, oxidation, nitration, soot, glycol and water. These along with the spectrographic results will easily tell you if the oil is in good shape or has been exhausted.
The analysis of the wear metals can give you an idea of where the wear is coming from. As others have said in this thread, the main sourse for the copper you are seeing is from the oil cooler and this means the one that comes standard in the radiator as well as additional add on varieties.
The only other real source of copper is from the main crank or connector rod bearings. I'm sure this is not the case because the lead that coats the copper to form the babbit of the bearings would have to wear through to expose the copper and you have not reported any high lead content.
The high iron can be from several sources and but usually is from the cylinder walls. In my experience, fuel is the most common cause of high iron. When the fuel injectors begin to spray raw fuel not atomized as desired into a cylinder it will reduce the viscosity of the oil at the ring cylinder wall interface and cause the wear of iron. You will not see any fuel dilution in the oil because it is vaporized by the temp of the oil and never shows up on the analysis. There may be an abnormal increase in nitration levels of the oil but not enough to really stand out. The partially burned fuel contributes to the nitration levels but this may only be and is likely only happening in one cylinder.
The quick fix if the problem persist, and it may not, is to go to a grade higher viscosity and this will maintain a higher viscosity on the cylinder wall reducing the iron wear. The other fixes are to use a good grade diesel additive and clean up the injectors for optimum performance.
The copper is an illusive problem that will come and go in Cummins over the life of the engine. It is really of little concern unless it is coupled with increases in lead.
If you can give me the rest of the sample results I can look for some more clues and see if there are other possibilities.
It was mentioned that the Amsoil 5W-30 has been known to shear out or toast out! This is a statement without merit; show me some credible evidence of this. I have never seen this in hundreds of customers and their oil samples. Please don't make unsubstantiated remarks that question the quality of the Amsoil 5W-30. It is obviously, a right to choose the oil of your choice but don't knock a product with rumor or unsubstantiated information.
I hope this info is helpful and if I can answer any specific questions on oil analysis please ask here or email me direct or click on my banner ad for Amsoil and check out the section on my website for how to interpret oil analysis.
Dan Watson
www.AdvancedLubeTech.com
