I've had 2 oil samples done now since buying my used '98 at 49,000 miles. This has been discussed before, but I don't recall what numbers others had. BLackstone labs completed and returned oil analysis results much faster than expected. Here's my numbers:
1st sample: About 6,000 miles on unknown 15W40 conventional oil, no makeup oil.
2nd sample: 3,100 miles on Delvac1 5W40 Synthetic oil, no makeup oil.
SAMPLE 1 (Universal average in parenthesis)
2 (4) Aluminum
1 (2) Chromium
11 (23) Iron
1 (6) Copper
2 (8) Lead
0 (152) Boron
403 (461) Magnesium
1005 (1070) Phosphorous
1047 (1208) Zinc
67. 7 (68-78) SUS Visc. (below "OK" level)
<0. 5% (<2. 0%) Fuel
0. 5% (1. 0%) Isolubles
420F (>405F) Flashpoint
SAMPLE 2 (Universal Avg. in parenthesis)
2 (4) Aluminum
0 (2) Chromium
9 (23) Iron
1 (6) Copper
2 (8) Lead
173 (152) Boron
463 (461) Magnesium
1125 (1070) Phosphorous
1164 (1208) Zinc
77. 3 (68-78) SUS Viscosity
0. 3% (1. 0%) Insolubles
No trace of Water or Antifreeze. No trace of tin, molybdenum, nickel, manganese, silver, titanium, vanadium, or barium (probably don't have most of these metals in our engines).
I thought it would be fun to compare well-used conventional oil with low-mile synthetic. I think I will wait until I reach 10K and resample it when I change it. The oil on the 2nd sample came out of the filter. At least 30% of my driving on these oil changes have been short-trip, running around town.
The conventional oil dropped below the "OK" range on viscosity, whereas the synthetic was on the high side of "OK". And there was no Boron, whatever that means. Most interesting: the conventional oil and synthetic oil had identical flash points. Where is the supposed synthetic advantage here??
3rd EDIT JOB: Decided to put numbers on the left so they line up enough to be readable!
Vaughn MacKenzie
1998 3/4T Quad Cab 4x4, 24-valve, 5-speed w/3. 54 rear, White over Driftwood, Fog Lamps, Air Dam, Agate leather with most options.
245/75/16 Kelley Safari MSRs on M/T Classics, DeeZee running boards, diamond tread bedrail & tailgate protector.
55,560 miles (1/11/00)
[This message has been edited by Vaughn MacKenzie (edited 01-14-2000). ]
2 (4) Aluminum
1 (2) Chromium
11 (23) Iron
1 (6) Copper
2 (8) Lead
0 (152) Boron
403 (461) Magnesium
1047 (1208) Zinc
2 (4) Aluminum
0 (2) Chromium
9 (23) Iron
1 (6) Copper
2 (8) Lead
173 (152) Boron
463 (461) Magnesium
1164 (1208) Zinc
Vaughn MacKenzie
