Engine/Transmission (1994 - 1998) Oil Dipstick
Engine/Transmission (1998.5 - 2002) Enough Automatics!
2nd Gen Non-Engine/Transmission Beware of lmc truck
My 94 has a broken handle on the oil dipstick. I have a 1996 dipstick and tube assembly that is a different length than the 94. If I change to the 96 tube, can I use the later model dipstick?
You could change the oil using the correct amount of oil for your truck and then check the oil to see where it comes to on the stick. Then you will be able to know whether or not you should add oil.
