Engine/Transmission (1998.5 - 2002) Oil drain plugs....
2nd Gen Non-Engine/Transmission new noise
I used the super plug from Genos for a while but then the last time I changed my oil the head stripped on it. Had to use one of those bolt outs to get it off and it wasnt over torqued either. I couldnt believe it did that. Went back to the stocker for that oil change. Have since ordered the one/finger touch one from Genos by fumoto or something like that and installed it my last oil change. Wont have to take it out again. Will see how it works next oil change. Appears to be made fairly well but so did the super plug. Chose the super plug orignally because of its design, seemed super heavy duty. The one touch I figured will not have to take it out again and shouldnt be a problem. Will see if it the ball valve in it holds up.
I just got one from Napa, was like $6. I drilled out the center about 1/4" deep and put a magnet with a bit of JB Weld to hold it in place.
29 changes with the Plug it Right, Heavy duty plug. Mine came with a magnet cap cover that I don't see advertised anymore. But, it's a stout plug with 9/16" nut and high quality threads.
I've had the easy-drain from Genos since my 99 was new. No problems in 108000 miles with oil changes every 5000. If you get one, make sure to warm er' up first or it won't drain right! Mike
dmhollister said:
I have the one touch drain installed and don't have to remove the plug anymore. One of my best free mods yet to the truck.
Both my dad and myself run the Fumoto plugs... one of the best time savers there is...
steved
I have the finger touch drain valve from Geno's and so far so good. Hangs a little low (sits about 1" lower than the oil pan) but I don't do any off roading, so it's ok.
-Troy
I have used the Fumoto drain plugs for over 15 years and have 20 to 25 in service. I have never replaced any of them due to failure. In fact I still have the first one in service I installed , that unit has over a million miles on it. Have to love them, install it once, never have to fight a drain plug again.
Ben
CCahill said:
Are these from Geno's... if not I'd like to see'em...
His is from Geno's, mine I got on eBay... just search for Fumoto...
They work great... better than farting around with a stuck drain valve.
steved
