therabbittree
ok i did my feed lines etc. . im working on my drains originally i was gonna drain both into one the stock single drain... but i have heard from a few reputable source that is a russian rolet etc as it may work but if it doesn't, you'll back up oil and waste a tubo seal etc... . so my blocks are early 12v blocks so i only have one oil drain stock. . so i either drill and tap the block or do a oil pan drain. . the engine is in the truck so even doing a oil pan deal isgonna be interesting to say the least. I have to see if i can snake it out. . its a '89 4x4 w350... if i pull both motor mounts and lift it up till i hit the fire wall maybe i can have enough room to pull the pan?... what do you guys recommend?. . hehe. . thanks
deo
\x/ hillfolk!
deo
\x/ hillfolk!
