What units are you using for restriction? I've never seen that equation before, and I'm trying to understand from where it's derived. Looks like restriction needs something like [g/(s*ft)].
I'm not using any unit, my equation is a general one. Pressure is a measure of flow time resistance. . no units needed. . just a very simple way to look at pressure. If you have a 3" hose moving "x" fluid then you will have "y" pressure. Take a 1" hose and move the same amount of fluid thru it then you have a higher pressure than "y".
Anyway, it looks like we're in complete agreement. The 15 mic filter has a greater restriction than the 25 mic filter, owing to the fixed canister size. Which means the 15 mic filter is flowing less oil. This must be true, or else why stop at 15 micron? Why not 1 micron? Or are you suggesting there's no more restriction with the 15 mic than with the 25 mic?
Were not in complete agreement. If you compare the same filtration media then yes we are in agreement, but Fleetguard and Amsoil/Donaldson use different filtration media's, so it is possible to have the same flow at 15um as 25um. In fact if you look at the OEM paper style filter you can probably get greater flow thru a tighter synthetic weave. This is why Amsoil/Donaldson filters have extended drain intervals, the media doesn't swell or vary from use. So as long as the filter isn't plugged it still flows the same. Direct from the stratapore website it states that the stratapore has lower flow restriction than its non stratapore counterpart. So right there it tells you that a good 25um filter can flow better than a cheaper 35um filter. So if the Amsoil/Donaldson media is better than stratapore there is no reason it can't flow the same or more. I would presume that 15um is the tighest you can go and not start to detract from flow.
If we can agree that decreasing particle size increases restriction, then how much restriction is too much? In other words, why did Cummins choose to stop at 25 micron? What are the flow margins on the Cummins B-Series?
Cummins most likely chose to stop at 25um because thats a pretty good rating for oil, and for most users its more than good enough. Amsoil/Donadlson went to 15um for that niche user that wants the best. Thats like asking why Dodge stopped at 325hp when programmers can get 400+ with all stock hardware.
What definition of efficiency are you using?
The absolute rating for a given filter, Amsoil/Donaldson are 15um absolute and Stratapore are 25um absolute (Both use ISO 4548-12). The Amsoil is more efficient at removing oil contaminates.
You are on the right track, though it may be possible to get finer filtration with the same area with a similar pressure drop by using a more porous media, but of course there are limits and there will likely be tradeoffs, such as weaker media or shorter filter life, etc.
It just depends on the media. The Amsoil/Donaldson has a finer rating as is a 25K mile filter, so the best of both worlds. If you look at this page
link you can see why. The synthetic media itself is smaller, so you have more openings for flow than with a conventional filter, thus the finer filtering and increased flow and service life. (Stratapore is a synthetic media as well, but I can’t find any depictions on it. )
Getting back to differential pressure across the filter, when looking at oil pressure in the block one has to remember the oil system has a filter bypass of 50 psid built into the oil filter head. The stock oil filter does not have an internal bypass valve while, iirc, Wayne (Amsoilman) said the Amsoil filter (made by Donaldson) does. Iirc he said it was set for around 10 psid. So it would not be surprising that the Donaldson/Amsoil filter produces higher cold oil pressure at the block, though it may do so by allowing more oil to bypass the filter element than would happen with the Fleetguard filter. I have no idea if that has any significant impact on engine life, though personally I want as little unfiltered oil as possible going into the engine and turbo.
Amsoil/Donaldson does not use an internal bypass on the filter for our engines, the only bypass is the 50 psid that is part of the engine. So there is no unfiltered more oil going to the block than with any other filter. . and I would guess even less based on the uniform flow properties of the nano-fiber material.
Anyhow, when only measuring the pressure in the block there is no way of knowing how much flow is going through the filter element and how much is bypassing it.
I can verify that no filter is bypassing the filter with my gauge. I can do this because as you stated the psid required to bypass the filter is 50psi. The oil pump has a internal bypass that only allows ~75psi thru the pump. If I am cruising at 2K rpms I have ~60psi of oil, if there was a 50psid at the filter that would mean that the oil psi at the pump would be 110psi, which isn’t possible based on the 75psi dump at the pump. If the psid were met to bypass the filter I would expect to see no more than 25psi at cruise rpms.
Hope that’s all clear as mud
I will reiterate that Stratapore filters are great filters, and if you’re just running normal drain intervals then they are the proper filter to run
