2nd Gen Non-Engine/Transmission Oil leak on 98...
Engine/Transmission (1998.5 - 2002) Suncoast 47RE Trans fluid
Engine/Transmission (1998.5 - 2002) Harmonic Balancer Question
Need to take a look under to see where it's coming from. Could be: Vacuum Pump, Oil Pan, Rear Main seal, lifter cover, KDP:eek:, Front Crank Seal, leaking pan drain plug, or just the timing cover vent tube, or, or, or = there's just so many possibilities.
