Originally posted by y-knot
The oil pressure on your truck is regulated/controlled by the on board computer, a signal is sent from the sender indicating you have at least 6 psi of oil pressure, and the computer sends a signal to the gage, showing the oil pressure in the normal operating range. The reading you get is not a true reflection of your engines oil pressure at all. Instead it is simple a pre-determined setting, that Dodge came up with to give the user some peace of mind. It is entirely possible, and has happened many times, that your engine can experience a oil pressure related problem, and the gage will continue to read normal. For who knows what reason, Dodge decided to have there gages programed to always read normal, weather the engine is normal or not. I had a Dodge run completely out of water and the engine got so hot, it cracked the head in three spots, while the temperature gage and oil pressure gage continued to read normal. I ask the head mechanic at the dealership why, and that is when he informed me that all gages in Dodge vehicles are basically dummy gages. They no more reflect what the engine is doing then the radio does.
If you noticed, my signature shows a vast array of gages mounted in my truck. I do not like being kept in the dark, nor do I like being deceived or lied to by a gage that has been programed to read normal. All I can say is, if you are truly concerned about your engines vitals, then get yourself some quality gages and monitor the engine independently. Good Luck
