Engine/Transmission (1998.5 - 2002) Oil seal between Vac and P/S pump
2nd Gen Non-Engine/Transmission Shock mount rubber
Engine/Transmission (1998.5 - 2002) Noisy Dual Disc???
Part number 4089742? Cummins has it for just under $8. For some reason I remember this seal being like $50???
If you get the kit from some other vendors, they will also have extras like a DVD and whatnot.
Don't forget to get a new gasket to go between the vacuum pump and the gearcase.
Do you need to pull the vac pump to replace that seal? When I put a new p/s pump I just pull the pump off.
It has been a while since I replaced the seals in my vacuum pump, but if I remember correctly, yes you have to take the vacuum pump off because the seal is installed from the inside. Also, when you can reinstall the vacuum pump/ps pump as a single unit and that will minimize the risk of "nicking" the vacuum pump seal with the sharp end of the PS unit.
Also the kits will have the o-rings and tools for doing the seal change. The seal that came in the kit I got was a double lip seal were as the original one was only a single lip seal.
Kevin
What tools do I need?
Info on these kits?
Truck is leaking pretty bad... dripping all over the ground now. Needs help!
