It has been a while since I replaced the seals in my vacuum pump, but if I remember correctly, yes you have to take the vacuum pump off because the seal is installed from the inside. Also, when you can reinstall the vacuum pump/ps pump as a single unit and that will minimize the risk of "nicking" the vacuum pump seal with the sharp end of the PS unit.
