Just before I bought the truck Craig Monroe Pushed it to ~13. 5. I've slept since then. at race weight it's 6900#.
It has a stronger clutch, bigger turbos (B1-big brother vs HY30-BHT3B), delivery valves(laser cut vs 191s), better injectors(edms now vs honed then) and dual stage nitrous.
I'm not making excuses for not making numbers. It just turns out that when the events come around the time and effort neccessary to make it run well has not been available. I truely believe there is al lot of unrealized potential in the truck. we had problems with clutches with the old turbos. once the clutch got fixed the motor had problems... when the motor went back together the head was cracked and we did not have a ready replacement. With the cracked head the new turbos were bolted on. Since then i've abused it on the street and the head went WAY south. . there's oil pouring out around the #6 injector. Let's just say that I'm not easy on parts
We keep putting on better stuff as time is available. I had to put a known bad head on to get the truck running and out of the shop.
a 13. 5 calcs to ~550. The clutch was not holding well and is the reason for going to the SBC DD. Craig is the best driver in a 5spd I've seen and even he could probably cut . 3-. 4 with an auto. leaving the line under boost and never loosing boost is a decided advantage, enough that I took th e 6sp out of the 24v dually for an ATS auto
the truck dyno'd at 580 on an H2E before the twins and dropped ~. 3 s off the ET with the turbo chage to an hy/38 setup.
BEFORE ANYBODY SAYS IT... I know the dyno is showing better than the ET. Manual trucks may do this because of LAG and shifting in the 1/4 mi. Auto trucks have the advantage at the track over the dyno becuase they are able load the motor hard at the line and continuously for the entire run. . loading the truck harder and longer than on the dyno.
right now the head is cracked and being replaced and the right front hub is rattling in a rather bad way. I have a fella that's interested in buying it so there will be time spent to fix the deficiencies. Hopefully I'll get it to the track and dyno before it goes.
The customer wants it to be a highperformance street/tow rig so it'll be getting smaller turbos, injectors, and delivery valves before it leaves. Even then it'll be a high 5XX truck like it was when I got it.
FWIW,
Mark
FWIW,
Mark
