Merv just made 627 on DIESEL ONLY!!!
I just talked to Merv (HuffnPuff). He dyno'd at 627 a day ot two ago after installing a new set of DonM's injectors.
He dyno'd at 572rwhp and ran a 12. 82@107 in his 6800# 2500SWB QC 4x4 24v auto with a smaller set of Don's injectors
That yields.....
Using the ET method,638 horsepower
Using the Speed method, 650 horsepower
Both runs were on a dynojet, diesel only. Why is the Dyno off by ~10%????????????
The HP he is actually putting to the ground is over 50hp above the dyno.
He's got a full on transmission . . i forget who's. . a set of my twins using hx35/40-14 & BHT3B-26, ATS manifold, DonM injectors, Drag comp, ported, fireringed, banjos gone. . there's more little stuff.
fyi...
http://www.fastcoolcars.com/hp_calculator.htm
from ...
http://www.geocities.com/spcofsparta/hpcalculator.html
Horsepower Results - 1/4 Mile Method
Your ram 2500 weighs about 6800 pounds and can complete a 1/4 mile in about 12. 82 seconds. That means that you've got about 637. 87 HP at the wheels, and about 829. 23 HP at the flywheel.
I found this on another site...
The ET method
This method uses the weight of the car and the time it took that car to travel 1330 feet (¼ mile).
The formula is: hp = weight / (ET / 5. 825)3
The Trap-speed method
This method uses the weight of the car and the speed at which the car completed the quarter-mile run.
The formula is: hp = weight * (speed / 234)3
