How close were you to being able to keep the heat exchanger?
With mine I could have raised the big turbo about 1. 5 inches and change the turbo to turbo cold pipe(or built it different) so you could clear the frame and make more room between the heat exchanger and turbo by moving it outboard(towards the fender) but there is a down side and that is the down pipe. When you move the big turbo towards the motor or the fender you loose it from being centered in the hole that the down pipe has to go through, if you are running a 5" down pipe then it is tighter and that is an issue, yes I could make a better down pipe than the one I have(tight on the transmission side) but this one works(the hardest part of the job) The heat exchanger isn't that big but the piece of crap it's mounted to isn't user friendly and I didn't want to cut anything up so off it came. You have to ask yourself do I want Twins and I'm willing to get around obstacles to get them or do I stay with a single. DTT sells a Big cooler for up front if you wanted to go that route and put fans on it if needed. I'll tell you I will not go back to a single, these are too driveable and too much fun.
Jim
