C. forget that the eccentric is threaded. The steel bracket itself should have a nut welded on the backside of the bracket. You should have a matching bolt. I'm sorry but I can't recall off hand what the bolt size is (I'm at home) but I believe it's 7/16 fine thread. Anyhow, you have to remove the black pulley, insert the bolt into the eccentrics hole (bolt is smaller than threaded portion), re-install the pulley, then thread the bolt into the bracket. You snug the bolt just enough to pivot the eccentric and tighten the belt. As you hold the eccentric with a wrench, tighten the bolt.
If everything was packed correctly, you should have the right hardware. If not, call the shop and tell Robert (I'll be out of town) what you're missing and I'll have him ship it right out.
