I have suffered one lift pump failure in my ownership of a 24V Dodge. And after reading hundreds of posts (and searches) regarding the failure of these pumps and looking at all the possible solutions to date... I have decided on the setup I am going with. First I must say I admire those who have taken it upon themselves to solve the problem using the various alternatives we know of. Commonly known methods involve pushers, relocating pumps, PE pumps, larger lines, better fittings, large banjo bolts, etc all in the name of better performance and reliability. And with all the good ideas passed along came my own vision of what I wanted. TDR members are innovative, helpful, responsive, generous, and just plain good people. Without all the prior posts on the issue, I would have been in the dark and maybe not even realized the problem existed.
This thread is not intended to raise the question of which solution is better. Some have never even had a failure. Rather it is a place where I will post what I have chosen and how it progresses during installation and operation. It could prove to be a flop but I feel comfortable I know what I want and how to get there. I feel I have a decent grasp of the problem(s) and I have the tools to make it happen.
My goal is to accomplish several things at once. Eliminate vertical lift for the lift pump. Shorten the distance from the tank to the pump. Provide clean filtered and water free fuel to the lift pump. Provide larger fuel lines for and aft the pump. Eliminate angled fittings altogether (of any kind). Make lift pump changes extremely simple (if ever needed). Provide a better final filter with lower micron ratings than OEM. Reduce the need to bump the starter to prime the system. Make filter changes extremely simple with no messy drips on the engine or frame... everything is under the truck. Make priming and bleeding air work for once on my truck. Provide super clean fuel to the VP at acceptable pressures (constantly). Give me something to do and have fun doing it
This fix is basically a Carter OEM pump relocation with a slight twist. I plan on having 1/2" line, twin Stanadyne Fuel Manager filters (80 GPH capacity each from a proven OEM supplier), and using the stock lift pump wiring harness to power the pump. I'm not going to use the stock fuel filter setup any longer and I will only have 1-90 deg. elbow in the system (AN type) at the VP44 inlet. All other fittings are straight through. The lift pump and filters are frame rail mounted and the hose runs right along the frame up to the VP44. No more trips through bends, banjos, etc. No more long draws and fuel traveling up to a high mounted filter only to come back down. I call it the linear approach to reducing pump stress. I really dislike the OEM filter canister and location... and everything else about it.
The fix first has upgraded lines coming out of the tank... 1/2" will do fine. It will also involve removing the bed, inspecting the tank, and removing the pickup screen mesh. I've yet to see this pickup assembly and I will modify it if I dont like what I see. Time will tell on this part of it. The fuel will travel to a Stanadyne Fuel Manager FM100 filter head mounted directly in front of the tank. This 30 mic filter (150 mic optional) will remove most water and impurities before the pump. The restriction by this filter has been determined very minimal during my phone conversation with Stanadyne engineering (great folks and very knowledgeable of the VP44 and lift pump situation). This filter head will incorporate a 150W heater, manual primer pump and a WIF sensor. Perhaps a see through bowl but I can always add that later (totally modular filter heads). The filter head is 3" tall and the filter is 4. 3" tall so the frame rail will protect it well. I'm adding skid plates and deflection shields to the bracket as well for added protection from debris and the elements. This will accomplish supplying the lift pump with debris free and water free fuel... two things which I believe help kill OEM pumps (among other things as well).
Secondly the lift pump will reside on another custom bracket that attaches to the existing transmission (5spd) cross member bolts. The cross member will provide some level of protection and the location will make it super easy to change if it ever fails again. The Cummins adapter harness will be lengthened a foot or two and should prove to be fine.
Finally a second Stanadyne FM100 filter head will be placed after the lift pump (about where the engine mates with the transmission) and incorporate a 5 mic final filter (2 mic optional). Both filters are rated for up to 80 GPM, will last 500 hours (10000 miles) normally, and are rather compact as compared to similar Racor units. Plus I dont have to run a clear bowl if I dont want to. There will only be a drain port at the bottom of these filters which can modularly adapt to a clear bowl later. This unit will also have a WIF and a 100W heater. Both heaters can run off the OEM wires as they are not part of the ECM, PCM circuits. The OEM wires have a 300W capacity through the power block heater relay. Both WIF sensors will operate in cab lights using their own circuits and sensors. The OEM WIF wiring however goes through the ECM and depends on the stock WIF sensor to feed the dash light through the CCD circuit. (not sure what happens to the dash light if I leave the OEM sensor unplugged permanently... hopefully nothing).
These components are to be mounted along the frame and will not extend down below the frame. I'm going to make sure they are properly guarded from debris using shields integral to the bracket. And I'm going to use holes already in the frame to mount it all... theres plenty already there. All painted black it should match OK and look kinda factory. All the fittings will be Aeroquip socketless -8 with black socketless hose (still unsure on this one). All the fittings can be straight with the exception of the VP44 inlet which has to be a sweep 90.
The output hose will leave the final filter and travel low and along the frame right up the the VP44. No elevation changes anymore for me. This makes sense since the VP inlet is already somewhat low to begin with. Top it off with a post-final-filter pressure sending unit and a shutoff ball valve prior to the primary filter and that should be it. I'll also upgrade the return line while I'm at it I suppose.
It seems like I'm leaving something out but I'm going to update this thread as needed and keep an accurate photo log in Readers Rigs for the custom work required. This aint quick, it aint easy , and isn't going to be a 1/2 day job... but its what I feel will be a good system when I'm done. Some may think its overkill and argue a pusher will do all that I ever need. But I have to go down this road now. Its too late to turn back. Stanadyne makes great looking modular filter setups and I haven't seen too much about them other than Scheids lift pump system (which is a version of the FM100) but I think I'll like it. This was long I know but I wanted to get my final answer (idea) to the lift pump saga out there. Not too wild I suppose but getting the OEM filter outta there and putting everything on the frame isn't often heard of. To each his own.
I often take the advice of a Vietnam War Veteran (helicopter gunship pilot) I know. When things go bad... do something... if it makes it worse... do something else... but do something.
EDIT NOTE: 15W40 is also posting some very interesting and promising information about building and testing an electronic lift pump control module that will pulse the motor on-off-on-off at variable settings (such as 10 times per second) to maintain a set psi output of the lift pump. This looks great for various reasons!
