I just wanted to drop a note that the system is complete and seems to be performing as hoped!!! I just got back from my first test drive and all went well... except for the strange looks I got from people staring at a pickup going down the road with no bed! It was kind of strange looking in the mirror and not seeing the back of my truck at all.
Before I hooked up the fitting to the VP, I stuck it in a 5 gallon bucket and ran the lift pump. This setup produces a very nice solid stream of fuel out the Aeroquip smooth 90 fitting. It almost felt as if I had a garden hose hooked to it. The is definately no absence of volume here anymore.
Anyway... I hooked up my spare pigtail I modified to hook directly to a battery. It primed twin filters and dry lines in about 8-10 seconds. I let it run for a good minute to completely purge all the air out. (I earlier also checked my VP return line pressure relief valve and it was popping open at around 13. 5 to 14psi). I unplugged the battery harness, plugged in the trucks harness and turned the key over. It started after cranking for about 5-8 seconds... sputtered for a second the took off nicely.
Idle was a solid 15. 4 psi and revving it up didn't drop it at all. Pressures are being monitored by my new Dakota Digital gauge mounted on the steering column. Its set to flash low warning at 8 and high at 18. They claim its fairly accurate so all my results are at the mercy of this gauge.
Driving around normally gave me a pressure drop to around 15. 0 to 15. 2. Wide open throttle in 5th going up a long hill gave me a 14. 6. That was the lowest I ever saw. I have the gauge on fast update so it takes readings every second or so to display. The good thing is that it doesn't vary up and down alot. It pretty much stays in the 14. 8-15. 2 range all the time. Plus this was all done with a 1/4 tank of fuel. A full tank might be even better. Also at 1/4 tank I noticed no loss of prime or pressure since I now have a gutted fuel module pickup (ie: no screens or check valves). I did a little analysis of this and figured all the fuel going away from the pickup tube would be a rare event at a very low tank level.
Thats all I have right now. A couple of friends are going to help me get the bed back on in a little while they I'll post some pics of the final installation in my album.
Its been hard work and cost a few bucks, but I think it was worth it in all.
PS: I did end up installing a nice little fuel rated ball valve for shutoff prior to the first filter. I'm glad I did cause it will siphon out all the fuel if I open the filter drain.
