I'm finally done
Here are the photos of my results. Lots of hard work but I like it. I hope it helps, or inspires others if they so choose to go to something like this. Screen settings should be bright to see details as the photo area was a little dark even with flash.
Stanadyne Filter System
Tonight I'll be tightening down the bed bolts and installing the rear bumper so I can really put some road testing on this.
The final filter is well protected as is the prefilter. However in the near future I'll make a small skid plate to further protect the prefilter. Later I'll also install the shorter 4. 5" prefilter. I only had to drill one small hole on the transmission crossmember and one small one for the 2nd prefilter bolt. All in all, I tried to use existing holes which worked out well.
Thanks for all of the suggestions and words of encouragement. Special thanks to Rod Snaith @ Wildcat Diesel (and Ed Looney) for those steel M12x1. 5 adapters (I didn't want aluminum ones and these were very nice).
Now I can rest at night.
