Nice piece Txdieselkid!! Now that warrants consideration. Having the return in the sump would definately prove to be worthwhile with respect to the low level situations. Seems like I read where some ford guys didn't like the return right on top of the suction however... I cant remember. Hot fuel I guess.
I agree a bottom sump is not the lowest thing on the truck but it is the lowest thing for some distance. Its just so wide open... almost as if its a skid plate albeit up higher than the axles. Just a fear of mine I suppose. But that unit looks pretty strong. Maybe a mini skid plate would help. That would be pretty easy I think.
(My photos wont be posted until tomorrow morning... nothing I can do about it tonight. )
Chryslers design that included the fine mesh was a good idea... but lacks in many ways. Its not bomb-worthy and I doubt they intended it to be. But the idea has merit.
Imagine the fuel module reservoir as a pitcher (pardon the simple analogy). The return dumps into the pitcher and keeps that pitcher full at all times. The excess return fuel just overflows the top level and it goes into the tank.
The pickup or feed hose is plumbed to below this so called pitcher and draws fuel off the bottom of the main tank. Surrounding the inlet to the feed hose opening is a volume (or chamber) made of super fine mesh membrane material. I'd say the interior volume of this membrane chamber is about that of a tuna can. So it prefilters the fuel the pickup tube gets. I have no idea what the micron rating is but I simply cannot see the holes... the stuff just looks like transparent wax paper. I think its poly cloth of some type.
Now... at the bottom of this pitcher is a check valve that is held closed by a light spring. If you fill the pitcher completely up... the spring is barely able to hold that amount of fuel. The check valve is also connected to the membrane chamber... such that if the check valve opens it will flood the chamber, and thus the supply line inlet, with fuel. Now the outlet to this check valve is also screened with this mesh so Chrysler wouldn't have any debris getting to the suction inlet.
So when does the check valve operate? Well, I figure it happens when its got a full pitcher of fuel above it (it always does) and the check valve is just begging for a little more help to open. That extra help comes in the form of suction from the lift pump. If fuel swishes away from the pickup assembly leaving it high and dry... that membrane chamber is then placed into a vacuum mode as the fuel inside it isn't able to quickly flow away with the rest of the fuel. Its fine enough to where it doesnt flow through too quickly. Thats a big key here I think. Then the inlet hose sucks the remaining fuel inside the membrane chamber while at the same time the check valve opens and floods the chamber with a somewhat continuous supply of fuel. Remember as it drains the pitcher... the return keeps supplying it so it would take a while before you ran the pitcher reservoir dry... then you'd be out of fuel. But the bet is that the swiching tank fuel would come back at some time and fill the membrane chamber from the outside again.
Sounds crazy I know but I had to get my ideas out of my head. Dont know if my description makes any sense but that has to be how it works and the photos will make all the difference in this crazy explanation using lemonade pitcher analogys.
If my theory is correct... then I've totally defeated this function on mine as I cut out all the membrane material unknowingly. Dodge shows the membrane chamber/filter as a seperate part but they dont sell it that way. Makes me mad cause its easily removable as a unit from the whole assembly.
Sorry for the long post again. And I still dont regret doing what I did. I'll be OK. Besides that membrane it too fine for me to flow good. I think its a decent restriction in some part.
They could have made life easier by simply putting the inlet suction point at the bottom of the inside of the pitcher and putting a one way rubber flapper valve on the bottom of the pitcher to let fuel in from below (main tank) and it wouldn't let fuel escape if the tank pressure on the outside of the pitcher went away. It would simply close as a one way valve. I'm tired now and cant keep my eyes open. Night all and happy dieseling.
