Ordered 2018 3500 Laramie CC 4D with Aisin - Returned to TDR
Broken E-Brake Release Handle, Common?
Uconnect 8.4 with Nav phone problems
barkerdl
Greetings,
I just pulled the trigger on a new Ram so thought it best to rejoin this forum. Had a '92 and received lots of good information to modify it to be as good as it could be. Upgraded to a 2003 Crew Cab 2500 and have had a great time pulling the fifth wheel all over the West with it. The old 2003 is getting long in the tooth and I am now retired and wanted a newer truck with exhaust brake and more "fancy" stuff. Will be posting the 2003 for sale when the newly ordered truck arrives in a theoretical 6 to eight weeks.
Looking forward to getting the new truck and hope to benefit from the knowledge and experience of TDR members so I can keep it running well for at least 10 years.
Dennis
Just replaced my 2004.5 2500 with a 2018 3500 Laramie crew cab with the Aisin trans. What a world of difference! You will love the exhaust brake and all of the fancy stuff.
Good Luck,
Dave
Congrats! I too made the jump to a Cummins. I had a 93 F-350 with a big block 460 and no go-go gadgets at all.
I have a 2018 3500 Mega cab Laramie Sport on order now as the upgrade.
Added the newly ordered truck info to my signature - thanks for the reminder.
I'm like a kid waiting on a new toy...
Dennis
After much thought and gnashing of teeth, went with the 3.42. Hope the lower 1st and 2nd gears in the Aisin make the difference.
GOOD MAN!!!!!!! I truly hope "I" was an influence in your PROPER decision!!!!!
Put 3.42 in your sig.
Report back when you have a few miles towing.
Added the 3.42 gear ration to my signature. Ordered the truck on February 26th, so will be a long time before it arrives and I can report on towing. May need to check into reinforcing the pin box on my Montana due to the added torque. :)
Dennis
I ordered my new 3500HD 4x4 CUMMINS/AISIN (non Dully) with 3.42 rear end in February - Are any of you concerned with the problems associated with throttle lag as being discussed on the other forum page?
Dennis
You should add it's a DRW or Dually
I think you should just cancel your order right now and not loose any sleep! :rolleyes:
Give yourself an additional pat or two on the back, Cummins12V98 :rolleyes:
Since he eventually disclosed it was a SRW 3500......and an actual pickup....I guess he ultimately had NO choice in the matter. ;)
