If the sensor is missing and you still have radical readings, test out the circuit before buying a new sensor. Parts places often won't accept returns on electronic parts.
SENSOR CIRCUIT TEST
(1) Turn the ignition switch to the Off position.
Disconnect and isolate the battery negative cable.
Unplug the ambient temperature sensor wire harness
connector and the overhead console wire harness
connector.
(2) Connect a jumper wire between the two terminals
in the body half of the sensor wire harness connector.
(3) Check for continuity between the sensor return
circuit and the ambient temperature sensor signal
circuit cavities of the overhead console wire harness
connector. There should be continuity. If OK, go to
Step 4. If not OK, repair the open circuit as required.
(4) Remove the jumper wire from the ambient temperature
sensor wire harness connector. Check for
continuity between the sensor return circuit cavity of
the overhead console wire harness connector and a
good ground. There should be no continuity. If OK, go
to Step 5. If not OK, repair the short circuit as
required.
(5) Check for continuity between the ambient temperature
sensor signal circuit cavity of the overhead
console wire harness connector and a good ground.
There should be no continuity. If OK, see Compass
and Thermometer Display Module in the Diagnosis
and Testing section of this group. If not OK, repair
the short circuit as required.
Dan
