Overfilling with OIL
High torque clutch vs backing a trailer.. 2wd lo question
HELP!!! My '98.5 Truck is REALLY Dieing
My owner's manual says 10 quarts oil, and the filter gets one.
Jiffy Lube says 12 to 14 quarts are required, and they know because they do this all the time.
Does overfilling with oil do any damage? How much over is OK, where is the danger zone?
James L Nunn
2001 Flame Red Quadcab 2500 2wd, Diablo Power Puck, K&N, 4" exhaust, BD 275 injectors, DTT TC & VB, brite lite, Viper Remote start, Turbo life saver timer, Practical Solutions boost module, Wastegate turnbuckled off
[This message has been edited by Jim Nunn (edited 05-13-2001). ]
The 24 valve cummins in our trucks take 11 quarts total. Gippy Lube is WRONG.
98. 5 ISB QC 3500 4X4 3. 54, PowerMax1, DTT TC & VB, TY303 225/70/19. 5's on Rickson Wheels, 275 Injectors, Mag-Hytec Transmission Pan/Differential Cover, 9000 LB Warn Winch, Ultra Board Running Boards, Westach Combo Boost/EGT Transmission Temperature & Fuel Pressure gauges, Pac Brake, 2-lo kit, CB, GPS, Rancho 9000's, ATS exhaust manifold, JRE 4" exhaust with muffler and resonator. Lifetime NRA Member
I know this topic was hashed over a little while back. Try a search on the topic. I'll see it I can come across it.
Ryan
Jim,
If they put enuff in so that the rods hit the oil that is NOT a good situation! Actually, I would stay away from these quick change outfits with a Cummins. Their overpaid employees are likely to fill it with 5W30.
Joe George
Eureka, CA
'95 2500 CC auto 4X4,3. 54,Combo EGT/boost guage,custom switch panel,PacBrake,TST #5,DTT TC/VB,Automatic motorhome steps on both sides,Foldacover hard bed cover,Cummins chrome kit,Black steel grill guard,Front hitch receiver
Your owners manual does not lie, Jiffy lube DOES. 10 quarts in the pan, 1 in the filter for a 24v. Jiffy lube is usually manned by a bunch of of people who are relitivley clueless. Or at least the one near me sure is. And what Jiffy Lube does oil changes in Turbo Rams "All the time"? are trucks are rare enough that i would think more than half the people who buy them are the "do it yourself" types who would change there own oil and not go to them?
Definitely 11 quarts. I know it's 1 quart short of a full case, cause I'm starting to build a collection of "spare" quarts of oil. If it were 12, there'd be no extras. #ad
FWIW: I do take my vehicles to the local Valvoline quickie change every once in a while when the weather is nasty. It's the only place around here that doesn't mind if you watch every move they make while they're working on the car -- so far, I've seen nothing alarming! They'll even use your oil and filter, cut you a discount, and not complain about it.
Greg
Y2K Dodge Cummins QC 2500 SLT Laramie 4x4 Long Bed, 4. 10/Auto, Forest Green/Driftwood, 265x75R16 Michelin LTX, 6 speaker CD, Camper/Tow/Plow Packages, Westin Black Nerfs, Mopar bedliner, Ultra bright diamondplate toolbox, K&N Filtercharger. Autometer EGT and Boost gauges with 2-gauge pillar coming soon!
http://www.rints.com/hammond for photos!
Ahhhhhh, but, my friendly Dodge dealer put 12 quarts in, and charged me for same till I wized up and started doing my own. He also torqued the drain plug to about 100 Ft / Lb. Neat Huh?
Same dealer that told me that heating up while towing with an automatic was due to core deposits n the Radiator with only 3,000 miles on the truck.
11 qts.
However, it is easy to see where some people may think that 12 qts is correct. The first time I changed the oil in my 98. 5, it took 12 qts to reach the full mark on the dipstick. Later I found out that the wrong dipsticks were used on some of the ISB's. The dealer replaced my dipstick under warranty.
I bet they're getting it mixed up with a PSD. Don't they take 14? Can't they at least HEAR the difference? I can't imagine not doing it myself. Too many chances for disaster when someone else is fiddling with your truck.
2001 2500; SLT; 4x4; QC; LWB; Auto; 3. 54 LS; 265s; Camper; Tow; Sliding Rear Window; Travel Convenience Group; Cab Clearance Lamps; BedRug; Forest Green; Isspro Pyro, Boost, and Trans Temp Gauges; 27' TT
Back when my '93 was due for its first oil change and I was due for retirement, I got to thinking that having changed my own oil since I got my first car, I was old enough to let some "kid" do it. I went to a chain lube place, but they were real busy so I had about a 15 min wait; after about 10 min. of watching the vehicles ahead of me being taken care of, I pulled out of line,chased around town and bought oil and filter, went home and changed my own---and still am. The looks of the people working there gave me the feeling I did not want their hands on my truck.
Vaughn
Fireman Dave hit the nail on the head - PSD's hold 14 q's to keep those injectors pumped up and helps keep the oil from thinning out.
12 quarts in the pan hasn't hurt anything yet and it keeps the garage clean of those 1 quart leftovers.
