2nd Gen Non-Engine/Transmission Overpressure cutout switch in 2001 RAM 2500 A/C system
Does the A/C system have a high/over pressure cutout switch to turn off the compressor if the high pressure goes too high? or does it have only a "Blow off" valve to let high pressure refrigerant escape? I am pretty sure the system has a low pressure cut out switch because if there is not enough refrigerant in the system the compressor will not run.
Thanks
