Engine/Transmission (1994 - 1998) P-pump ideas...
I am building a 24v with a p-pump conv. I have a pump off of a 96 that I put delivery valves in but have been told many times that I still won't see the power that I would from a 215 pump out of a 97. . Is this true and if so would I be better off just getting a 13mm plunger pump built or is there a way to get the parts and have a local pump shop do the work? I have also looked at a p-pump from an 8. 3 cummins that is supposed to be 275 hp. Would this bolt up and be a better choice? I am somewhat on a budget since I have the whole truck to build along with the engine. Any help or opinions would be appreciated
Thanks for the info. Other than del. valves fuel plate and gov. springs, what else could I do to gain power? I am not too worried about streetability since it will probably be non intercooled with water/meth unless I can find parts to maybe build an air to water intercooler
