I have almost finished a KDP tab and oil leak fix on a friends 98' 215 which included cam and timing case removal. I'm about 200mi from all my shop manuals so I did everything off the interweb. The cumminsdatabase page was the most complete instructions I found but they had a few major short comings. 1, they said to make the wood dowels to a sharp point, they just break up when you hammer them in, got some wood in there now. Found a video on Utube that shows the dowels with just a slightly rounded edge, problem solved. 2, Having only done VP R&R before I was expecting a key on the Inj pump shaft, so the gear came off unmarked with the pump unlocked and the cam gear unpinned, learned about those tonight. The gear marks are all at TDC but after reinstalling the inj pump gear nut I know that I'm alittle advanced, tried to get as close as I could. So on this motor, stock w/afc housing forward what do you think? She tows 20k regularly. No comments about this being a issue on the instuctional page, sure other have done it. Here's the link to the instructions,
