I have been having trouble getting anything over 26psi boost lately and that's with both the Juice and the EZ installed. I should be easily able to hit 40+, I never use the higher levels. It's been cold here and my whole truck is covered in roadsalt so I waited until I got it cleaned out to start wondering what else it could be.
Along with the low boost has been very high EGT's. I can quickly and easily hit 1400* with the Juice on "0" and EZ on it's lowest setting. I decided before I do any damage I should pull the EZ out. I've only started the truck once since removing the EZ, and this code shows up along with the CEL.
P0069 MAP-Barometric Pressure correlation.
Do the two have anything to do with each other. I haven't taken the truck down the road yet as I am also working at tracking down a wiring issue with the trailer.
TIA
TIA
