Details here: TDR Privileges
Data link circuit failure between ECM and fuel injection
pump. Low power, engine derated, or engine stops. "
If the truck is running OK, then I'd say it had been a bad connection between the VP44 and the engine harness. The code will go away if there is about 30 starts with out an recurrence, not sure when the MIL lamp would go out
If the truck doesn't run, then I'd say to Disconnect, Clean with contact cleaner or alcohol, and resemble the plug between the VP and the engine harness. Moose00
