P1693 Trouble code
deathshake
Eth Injectors In A Etc
After running out of fuel twice due to a faulty gauge and loose nut behind the wheel I have trouble code p1693. What exactly does this refer to . I recently Installed the EZ. But I think the code was there before installing.
P1693
"a fault has been generated in the companion engine control module", or a "companion DTC" was set in both the ECM and PCM.
Hi Fred
Originally posted by Fred Swanson
Pull the PCM connectors and reconnect, it should clear.
Do you have to disconnect the batteries and then the pcm connectors or just unplug at the PCM? Sam
Setup
Usually unplugging the PCM connectors will clear this code. Sometimes I've had to leave it unplugged longer.
Sam, How's your setup doing?
This is the smoothest and most useable power combination I have tried to this point. I would like to try an hx40-12 or 14 housing. Thanks for the "GREAT SERVICE" :D . Sam
