P1753 again
Coolant ooze
2004 Dodge Ram Shifting Problems
Last weekend I posted in 911 about P1753 I had on my truck. I changed the TTVA and had the code reset thinking that was the solution. About 15 miles into my return trip home with the camper I felt it go into derate again. Limped my way home and checked it with my little code reader. Same code. I have checked the harness and plugs and operation of the TTVA. Does anyone have any other suggestions? I'm going to try and see if my Mac mentor will let me read governor pressure tonight
That code is for gov pressure not being as high as the ECU thinks it should be with observed throttle position. Next thing to change would be the transducer and gov solenoid to see if they are the source of the problem. After that, throttle valve on the VB is notorious for wearing and not setting correctly or jamming.
Thank you. That was my thought also The valvebody is removed and going to a highly recommended shop. Will let you know the end result
