I need some help from my fellow Dodge owners or anyone who has installed a Pacbrake. I spent about six hours installing the whole Pacbrake set up on a 2001 6-speed. I was really proud of the install it went well but I work slow. Here's the problem, It doest work!! When I flip the switch I have power to the relay
but nothing happens. ( yes I know there is a 3 sec delay) I'm running the black wire as per instructions to the #20 pin in the ECM. and the red to the vacuum solenoid. I've checked all the vacuum line routing a dozen times, I can find nothing wrong I'am beginning to suspect a bad relay . All the ground wires that have to be attached are to bare metal. I give up ! HELP!!!!!:{
