Engine/Transmission (1998.5 - 2002) Pacbrake or BD for auto
mroidt, Me bad, not you, on the assumption of the pxrb--this is a thread for the 24 valve CTD, not the 3rd gen--I hijacked it,, but was not careful enough on the details. In any case, I do MUCH appreciate your looking up the BD review in TDR#49.
SNOKING, are there any disadvantages to down line exhaust brakes? I don't really plan on bombing my truck past 65 additional hp, perhaps with a Superchips Firefly box, so I don't really see replacing the stock turbo.
Well if you are looking at a brake then you tow. Cooling EGT's is an issue towing. If I had it to do again, I think I would install an inline. I went from a HY35 to a PDR35 to cool EGT, but have not tow much yet. Will be doing a 6-8 week RV trip this fall thru the western states. Hopefully I will be able to use my power better now.
My son was a Banks dealer, so I ended up with that brake. They have both 3. 5 inch and 4 inch brakes. I went with the 4 inch. Ended up getting both the down pipe and intermediate Banks pipes to create a bolt in installation. SNOKING
SNOKING, after looking at some other threads regarding the PDR35, I would like to clarify with you that
1) it is a good match for an edge ez box,
2)it will more than likely help keep EGT's in check while towing
3) it is compatible with a turbo mount brake like the BD or PRXB
and 4) all of the above holds true for a stock 2005 HO CTD, which I believe already has a 4" exhaust
Thanks for all your time and ideas!!!
I know nothing about the 2005's. This is a 24V thread. Sorry. SNOKING
CFish
I looked up the #49 and found nothing on
exhaust brakes, you might wanna check
again on the issue #.
PS Leaving on vacation won't be able to help you out now either.
