I just recently installed my PacBrake and had a question regarding the switch which lies on the throttle pedal.
The instructions clearly say that the switch lever should sit in front of the throttle lever, but there is no way i could manage to get that to happen. Is this a typo?
I have the level BEHIND the throttle pedal.
They talk about how it should click when you let off the pedal, and mine does, but what they don't explain is WHICH click you want to hear--the switch being pushed away from the neutral position or going back to it.
I guess the basic bottom line of this question is--when you are not on the gas at all, not touching the pedal, etc--should the throttle switch be in the neutral or activated position? When I step on my pedal, it lets pressure off the switch and goes to a neutral position.
