Painless wiring hookup
Bushwacker Fender Flares
BOMB your Factory Service Manual!
I was hoping someone help me in hooking up the switched hot lead to the Genos interior painless wiring fuse box. A vendor that installed my EBrake and Torqueloc used a spade connector right off the interior fuse box. I would like to move that to the new wiring fuse box. Also I believe that most people are mounting the fuse box under the drivers seat?
The Blue Wire
Pull off the dash panel below the steering wheel. Locate the wiring bundle sort of under the steering column. There is a 10 or 12 gauge solid blue wire in the middle of that bundle. This is the switched 12v power.
I used it for my Painless switched power source. Some people have mounted their Painless panels behind this dash panel. I mounted mine under the dash up above the brake switch.
Re: The Blue Wire
There are 2 blue wires in that bundle, if you have problems with wire guages like I do the smaller one of the 2 is the one B9MILE is referin to.
