Parking Brake Indicator Light
CALLING ALL 2003 - 2005 OWNERS who want better lighting...
Truck bed tie downs
CROW
Truck is an 05 dually with a six speed. The parking brake works as it should. Since the truck has a manual transmission, I apply the parking brake each time the truck is parked. However, the indicator light on the dash will not work. When the key is first turned on, a steady "BRAKE" light will come on whether or not the parking brake is applied, but will go off in a few seconds whether or not the parking brake is applied or not. Checked the switch on the left kick panel that the parking brake arm activates and it is a very simple deal and it appeared to be OK. It makes and breaks connection as it should. There is a single wire that attaches to the switch and it had just over 11 volts coming to it. I'm lost and any help would be appreciated.
Ground the wire and the voltage should go to zero. The cluster should also turn on the brake light.
A brake indicator is standard equipment on all instrument
clusters. This indicator is located near the lower
edge of the instrument cluster, between the tachometer
and the speedometer.
The brake indicator consists of a stencil-like cutout of the word BRAKE and the International Control and Display
Symbol icon for Brake Failure in the opaque layer of the instrument cluster overlay. The dark outer layer of the
overlay prevents the indicator from being clearly visible when it is not illuminated. A red Light Emitting Diode (LED)
behind the cutout in the opaque layer of the overlay causes the indicator to appear in red through the translucent
outer layer of the overlay when it is illuminated from behind by the LED, which is soldered onto the instrument
cluster electronic circuit board. The brake indicator is serviced as a unit with the instrument cluster.
OPERATION
The brake indicator gives an indication to the vehicle operator when the parking brake is applied, when there are
certain brake hydraulic system malfunctions as indicated by a low brake hydraulic fluid level condition, or when the
brake fluid level switch is disconnected. The brake indicator can also give an indication when certain faults are
detected in the Antilock Brake System (ABS). This indicator is controlled by a transistor on the instrument cluster
circuit board based upon cluster programming, electronic messages received by the cluster from the Controller
Antilock Brake (CAB) over the Controller Area Network (CAN) data bus, and a hard wired input from the park brake
switch.
The brake indicator Light Emitting Diode (LED) is completely controlled by the instrument cluster logic circuit, and
that logic will only allow this indicator to operate when the instrument cluster receives a battery current input on the
fused ignition switch output (run-start) circuit. Therefore, the LED will always be OFF when the ignition switch is in
any position except ON or START. The LED only illuminates when it is provided a path to ground by the instrument
cluster transistor. The instrument cluster will turn ON the brake indicator for the following reasons:
² Bulb Test - Each time the ignition switch is turned to the ON position the brake indicator is illuminated for
about four seconds as a bulb test. The entire bulb test is a function of the CAB.
² Brake Lamp-ON Message - Each time the cluster receives a lamp-ON message from the CAB, the brake
indicator will be illuminated. The CAB can also send brake lamp-ON messages as feedback during ABS diagnostic
procedures. The indicator remains illuminated until the cluster receives a lamp-OFF message from the
CAB, or until the ignition switch is turned to the OFF position, whichever occurs first.
² Park Brake Switch Input - Each time the cluster detects ground on the park brake switch sense circuit (park
brake switch closed = park brake applied or not fully released) while the ignition switch is in the ON position,
the brake indicator flashes ON and OFF. The indicator continues to flash until the park brake switch sense
input to the cluster is an open circuit (park brake switch open = park brake fully released), or until the ignition
² Actuator Test - Each time the instrument cluster is put through the actuator test, the brake indicator will be
turned ON, then OFF again during the bulb check portion of the test to confirm the functionality of the LED and
the cluster control circuitry.
The park brake switch on the park brake pedal mechanism provides a hard wired ground input to the instrument
cluster circuitry through the park brake switch sense circuit whenever the park brake is applied or not fully released.
The CAB continually monitors the ABS system circuits and sensors, including the brake fluid level switch on the
brake master cylinder reservoir, to decide whether the system is in good operating condition. The CAB then sends
the proper lamp-ON or lamp-OFF messages to the instrument cluster. If the CAB sends a lamp-ON message after
the bulb test, it indicates that the CAB has detected a brake hydraulic system malfunction or that the ABS system
has become inoperative. The CAB will store a Diagnostic Trouble Code (DTC) for any malfunction it detects.
For further diagnosis of the brake indicator or the instrument cluster circuitry that controls the LED, (Refer to 8 -
ELECTRICAL/INSTRUMENT CLUSTER - DIAGNOSIS AND TESTING). The park brake switch input to the instrument
cluster can be diagnosed using conventional diagnostic tools and methods. Refer to the appropriate wiring
information. For proper diagnosis of the brake fluid level switch, the ABS, the CAB, the CAN data bus, or the electronic
message inputs to the instrument cluster that control the brake indicator, a diagnostic scan tool is required.
Refer to the appropriate diagnostic information.
SAG2--Appreciate your detailed response to my question. These trucks are complicated to us amateurs. Well done. I ran the instrument cluster check and found no codes. Again, thanks.
