Part #
Installing Steering Shaft
Front End Bushing
I am prepping a 91. 5 intercooled Cummins to go into my Suburban. I am making some changes to the fuel system. Last night I was removing the line that goes directly into the injection pump and bent it. I need to replace this fittting. Does anyone know the part number?
Do you need the fitting that threads into the pump or the metal fuel line that threads into the fitting? I have a spare fuel supply line you could have for shipping.
If you are building a custom fuel system, the inlet to the VE is 12mm x 1. 5. I used a 12mm x 1. 5 X -6 AN straight union. Then a 90* -6AN x -6AN elbow. The OEM fitting I plan to keep as sometimes they get boogered up, and I have 2 other VE powered engines in the family that would need it.
I need the threaded piece that bolts down to the IP. When I pulled it out it wouldn't budge and twisted the fuel line and screwed up the piece. I am redoing the whole fuel sytem and cutting away most of the hard delivery fuel line. I appreciate the offer.
