parting 1996 ram 2500 and many parts
AutoMeter Electric Fuel Pressure Gauge
Dodge 24 valve Van Aaken box and 47re Pressureloc
i have a 96 dodge ram 2500 that im parting out, very fast has lots of performance parts installed, and i have lots of other 2nd gen performance stuff for sale
borg warner s300 turbo 63/68/14 t3 flange, has 3rd gen compressor outlet and hx40 downpipe flange, paid $1750 8 months ago from diesel auto power, no shaft play or leaks makes 45psi SOLD
goerend triple disk low stall billet converter with lifetime warranty paid $1295 and had to give a core, SOLD
ats 3 piece exhaust manifold SOLD
rebuilt 47re with 8,000 miles on it, has trans-go shift kit, extra clutch in forward drum, hd clutches, many performance upgrades $1500 no core $1300 with a core
engine includes 330 hp marine injectors $1500 will be a bare engine, no accesories or bellhousing adaptor or injection pump SOLD
front and rear axles, 3. 55 gears, SOLD
np241dld transfer case in great shape, clean fluid, does not pop out of gear SOLD
smoke stacks with crossover pipe and elbow to hook up to stock exhaust SOLD
17" rims and 285 70 17 mud tires (new) from a 2008 ram 2500 SOLD
i have a couple of pcm's for 96-97 diesel rams SOLD
ported 12 valve head with new 60lb valve springs, all new valves and keepers machine shop fresh, never installed $1300 with gaskets
performance cam, copy of hamilton cams big stick drilled and tapped for gear retainer for 12 valve new in box with gear and retainer paid $415 sell for SOLD
complete cummins recon engine 12 valve remanufactured in 2004 from a shipping yard truck low hours injection pump removed but still have $1300 without pump $1500 with
set of rocker arms and pushrods from a reman 12 valve $100 great to have machined for head studs
he341cw holset turbo off 2004 24 valve truck was on my dodge, spools great makes 40psi no shaft play or leaks, great small turbo for twins or upgrade for stock hx35 $450
lots more stuff just have to look around, no scams, no lowball offers, no trades unless you have 6. 7 cummins performance stuff
all prices plus shipping
best and most reliable truck so far, never left me stranded, heck it never acted up. hate to part it out but would cost too much to rebuild the body
Can't compete against those p-pumped 12v for pure reliability. I love my 1997 12v. It's helping a lot in paying off the debt. My last truck was a wasted $30,000 vehicle. I got got no money back for it even when I sold it. The $$ on repairs equalled out the money I got selling it. Goodbye forever to Furd. (And it was a 2002 2 year old FX4 ranger at the time)
rear spring blocks
Do you happen to have the factory rear axle spring blocks and shackle u bolts
if so could you email me (rchilders9@gmail.com)
borg warner s300 turbo 63/68/14 t3 flange, has 3rd gen compressor outlet and hx40 downpipe flange, paid $1750 8 months ago from diesel auto power, no shaft play or leaks makes 45psi sell for $1200
goerend triple disk low stall billet converter with lifetime warranty paid $1295 and had to give a core, sell $1000 with paper for warranty
ats 3 piece exhaust manifold 2 years oldpaid $375 sell $200
rebuilt 47re with 8,000 miles on it, has trans-go shift kit, extra clutch in forward drum, hd clutches, many performance upgrades $1800 no core $1500 with a core
front and rear axles, 3. 55 gears, synthetic fluid used $500 each
np241dld transfer case in great shape, clean fluid, does not pop out of gear $250
smoke stacks with crossover pipe and elbow to hook up to stock exhaust $150
17" rims and 285 70 17 mud tires (new) from a 2008 ram 2500 $1000
i have a couple of pcm's for 96-97 diesel rams $50 each
ported 12 valve head with new 60lb valve springs, all new valves and keepers machine shop fresh, never installed $1500 with gaskets
performance cam, copy of hamilton cams big stickdrilled and tapped for gear retainer for 12 valve new in box with gear and retainer paid $415 sell for $300
complete cummins recon engine 12 valve remanufactured in 2004 from a shipping yard truck low hours injection pump removed but still have $1600 without pump $1800 with
Do you have a performance air filtration box and tube available? If winter hadn't hit earlier here in the mountains causing the contracting biz to slow seriously I'd want that trans and transfer case too. May think of some other things though as well.
Thanks, Todd 661-472-5317
sorry, i just used an aem filter on the stock flex tube
i have them, and as soon as i pull the diff, i will let you know. i am not sure if the U bolts will survive the removal process
most parts have been sold, i still have the trans, price lowered to $1500 or $1300 with a core, goerend converter $1000 lifetime warranty and no core, front or rear axle $450 each, frame and cab $350 with clear illinois title or $1100 with the axles and suspension still installed. clean and tight he341 $400. ported head with new valves, springs, keepers, and gaskets $1200. recon reman 6bt 12 valve industrial engine with low hours could be used as a 24valve by putting your pistons and rods into it. it has the crank sensor hole in the block would make a great 53 block replacement
