I have a 03 Dodge 250 4x4, 5. 9 S0, LB Quad Cab. The Dodge specifications says the payload is 2260 lbs. Now here is the question, when calculating the hitch, moma and myself am I overloaded? If I am, what can I do about it? I have heard that that there is a little give in the numbers. I also read that the SRW 250 is the same as the SRW350 minus an extra spring in back is this true is that the solution an extra spring? It came with a plow package, someone in a forum said this gives a little extra spring capacity in the front, is this true?
Max Payload 2260 lbs
Dry Hitch weight 1686 lbs
Hitch 220 lbs
Moma et moi 360 lbs
Overload? -6 lbs
Looking for info tinman.
Hitch 220 lbs
Moma et moi 360 lbs
Overload? -6 lbs
