Matt400 said:Is there a reason you wouldn't want to also have timing?
I ran a TST PMCR and, aside from the power, it was not a highlight of my truck ownership experience due to the codes and other weird crap going on with it. jwilliams3 runs the TST PMCR without any issues on his 04. 5 with the Scheid cam and has stated to me in PMs that the TST has complemented the cam quite well. If Edge comes out with the 305/555 juice or VA with its timing/duration box they're supposedly working on, then I'll definitely be going for those to try. If Edge or VA do not come up with these boxes then I'll stay with the simple pressure box. I have a used DD TTPM coming in the mail and it should give about 25 more HP over the VA, but I do like the VA in-cab adjustability. (I might even try one of Quad's new xzilleraider boxes, just for the in-cab adjustability, but reading about code issues has got me worried still).
Matt400 said:When you say "stock" are you saying your current turbo spools up faster than your stock turbo did or the HTB2 with or without boxes?
The cam made my current turbo (HTB2/62/14 cm2 exhaust) spool up EARLIER in the rpms (=faster) than my previous HTB2/62/12 or even the stock turbo off the lot (note smaller 12 or 9 cm2 exhaust housings, respectively).
I NEVER ran the cam with the HTB2/62/12 or with the off-the-lot turbo. When I ran electronic boxes the HTB2/62/12 spooled the same as the off-the-lot turbo. So by "stock" I meant the HTB2/62/12. Sorry for the confusion.
As an aside, all the people I've corresponded with told/warned me that the cam change is subtle and I really would not notice it until I start driving the same roads that I do day-in and day-out. When I started noticing it was the post-installation test drive in city traffic where I usually get lazy in down-shifting when the rpms got low and just feathered the throttle instead. To my surprise it just started noticeably pulling without any lag! Then there was the drive home and now back in town on familiar roads where this is further highlighted. Curvy roads, with lots of speed changes and small hills, are where the cam change really, really shines IMO.
Matt400 said:The 2mpg increase you have seen, do you feel is from the cam or injectors? Probably hard to say without trying one and then the other. I see both manufactures claim a 1-3 mpg improvement. ?
I feel the mileage improvement is definitely from the cam. I PMed Keith from DD and he was pretty upfront and said if I drove conservatively then up to 1 mpg; otherwise the mileage would be the same. I definitely do not drive conservatively! I'll have another mileage update by the end of the week (50/50 city/high speed NV backroad/interstate). IIRC Battering Ram on DTR did the cam change without injectors and got the same mileage improvements.
Matt400 said:Do you feel your combo is good for towing?
I haven't towed with this yet, nor am I a heavy tower if I did (car trailer with jeep that's almost rebuilt), but with the EGT, mileage, and lower rpm performance then I would imagine so. I may or may not turn down the pressure box, though, depending on conditions. If someone is in this area and wants to hook up a heavy bumper pull trailer then I'll be all for it for a test!
Matt400 said:Last. . I see that DD has posted this statement on their site:
Quote:
Injector applications require the use of one of the Edge modules
Why do you suppose that is? Since your running the adjustable VA I would wonder what happens to drivability and mpg's if you were to turn it off?
I think that is for the boost fooling from these modules. I drove around a bit with the VA off, i. e. boost fooling mode only, and the drivability/power delivery is still there (obviously "X" HP less). I was actually thinking of running the VA off for a tank, but having the power without having to watch the gauges a lot is sure relaxing and enjoyable!
A word on how the injectors feel with the pressure box off. The injectors feel like 100 HP from electronic boxes, but the power delivery is smoother with no surging type feelings (like in cruise control) and "foot position" on the throttle feels similar. I had a hard time understanding this concept from what I researched in the 1st and 2nd gen forums, until I experienced it. Maybe previous 1st/2nd gen owners can expand on this?
Also, at sea level with DD3 injectors: VA off = no smoke; VA 100% = minimal haze then quickly clears up.
At 5,000-6,000 ft with DD3 injectors: VA off = minimal haze then quickly clears up; VA 100% = about 2 second dark black cloud "puff" then clears up quickly.
Note that at 5,000 ft WITHOUT the injectors and WITH the VA = 100% I would get a minimal haze, which quickly cleared up, just to put things in perspective.
The smoke with DD3 injectors and VA = 100% is not even close to being like how the Bully Dog Pup was on Performance and Extreme. The BDDL was a smoke spewin' box!
Hope this answers all your questions - I just spent 1. 5 hours on this response trying to pick the right words without trying to create more questions :-laf !!
