Competition PDR's Blower on 5.9
Competition Florida Dyno Day jan 10th
Off Roading Score Laughlin Race 24th and 25th Caravan
well done there PDR it would be nice to hear how it acts in a truck if you ever get that far(which it looks like may be happening)---why the 'ell the talk about lag--you guys kill me--the only time lag comes into effect any more is on the street --everyone power brakes now to get past the lag if they race on the track or sled pull and if they don't then it's their own %$^* fault---chris
Jeff,
Your sick. :-laf
DieselNasty,
The air is drawn in through the twin turbo's for the blower, but the blower drives the turbos before it cuts out. Bottom end is wicked, just need to work a bit on the top end. We'll get it balanced soon.
Chris,
Good to hear from you. :)
So the blower "suck starts" the turbos?
A belt driven Monica ... life is good.
sbentz said:
Keep up the testing, Piers. The theory is sound, and may have application. I had thought of it, but glad you are trying it. Keep us all informed.
May be real good for us "thin air boys" up in Rockies.
Hell yes on the thin air boys part... and it would look pretty darn cool peeking out of the hood. :D
As a matter of fact it works great.
Bottom end is alsome and you only give up 16hp in total but we gained 3. 6 X more hp and ftlbs at lower rpm's until 2200 rpm's were the hp caught up and 2300 rpm's for the ftlbs to catch. At 1800rpm's with a HX35 the truck made 82. 7hp and 244ftlbs. With blower and HX35 the hp was 305hp and 900ftlbs. In 100 rpm's it hit 360. 6hp and 1007 ftlbs. :D
Now that's useable power.
Piers said:
Yep, but only 2 turbo's..... right now
Mark- you mention HX-35 and the Blower- so is this a single or twin set-up here?
And you report on lower RPM hp numbers- what about the good upper numbers where you would use a setup like this at the big end of the track?
Or is this design for the street?
Seems like alot of money and work for ONLY a piddy little 350 hp... ... ... ...
Hasn't 350 hp been seen with JUST an HX-35? 400h. p. as well? (high EGT's but 400+ none the less?)
What RPM's have you seen this set-up choke off?
But to have over 1,000ftlbs at that low of an RPM is nuts. :eek:
I know of one truck that hit 490+ on a stock 35. The only thing limiting it any more was the completly stock fuel system. EGT's might have been through the roof, but this was a dyno where it's all or nothing remember. ;)
Sled Puller said:
Nascar mark,
Here is some incentive for you guys to actully put it IN a vehicle:
http://www.diesel-central.com/forums/default.aspx?mode=thread&TopicID=2696
Maybe give you some fresh ideas, different direction to go. :)
I see a flaw it that car's plumbing,the way it is in the pics the supercharger isn't doing anything until the turbo spools. I say this because the supercharger pulls its intake air from the I/C and the goes to the y-pipe and the y-pipe goes back to the I/C so the charger is just dumping back into its intake until the turbo spools. they need to put a butterfly in the I/C side of the Y-pipe to keep it from backflowing.
